Can you return non-apple brand items back to apple retail store?
Posted by: pqrst
Date: April 13, 2019 11:26PM
I was thinking of buying the new $400 sonnet egpu. Can I return it or is that restricted to branded product?
Re: Can you return non-apple brand items back to apple retail store?
Date: April 14, 2019 12:24AM
If you bought it at the Apple Store, you can return it to the Apple Store.
Posted by: pqrst
Date: April 14, 2019 11:37AM
Ok. If I do spring for the egpu then i’ll ask at the store too.
Posted by: jdc
Date: April 14, 2019 12:36PM
If you bought it there, you can return it there.
I see appkle only sells the puck w/570.
Looks like a 580 is siginificantly faster? Maybe you could build a case + 580 for just a bit more..
[barefeats.com]
Posted by: pqrst
Date: April 15, 2019 11:03AM
Apple just added the 560 at $400.
[www.apple.com]
I am interested in it for use with a thunderbolt 2 hence wanting to be able to return if it didn’t work out. Also there is mention of the fact that it can’t be used with copy protected material (ie: DVDs) so again wanting to be able return it. $409 for a doorstop seems a little high. smiling smiley
Edited 1 time(s). Last edit at 04/15/2019 11:04AM by pqrst.
Guests: 243
