SSD mount & restore problems
Posted by: Mr Downtown
Date: July 25, 2020 01:03PM
Yesterday my Mac Mini declined to boot, with the ? folder flashing. I'd had it in my luggage for a 10-day Wyoming trip, but can't see how that's particularly relevant.
Anyway, back home today, I restarted with Cmd-R, and that went fine. But in Disk Utility, all the options other than Info, New Image, and Convert are grayed out. "disk1" shows (along with a second hard drive where I store big data) in the list, but Mount is grayed out.
It seems obvious that I should immediately buy and install a new SSD (I do, luckily, have an up-to-date Time Machine backup). Any recommendations? But I'm wondering if there's anything else I can try to get back in operation today.
Edited 1 time(s). Last edit at 07/25/2020 01:12PM by Mr Downtown.
Re: SSD mount & restore problems
Posted by: anonymouse1
Date: July 25, 2020 01:39PM
So the disk shows up, but won't mount? Both disks won't mount?
Was this the first startup after the trip?
Date: July 25, 2020 02:57PM
The other disk (conventional HD) seems mounted. Repair is available, as is the Unmount command.
This was the first startup after the trip. Actually, I had tried hooking it to a motel room TV (to use as a monitor) Thursday night, but as soon as I saw the ?-folder, I just packed it back up.
Posted by: testcase
Date: July 25, 2020 03:20PM
Was you luggage scanned at any time during your WY trip? If it was, I'd suspect that said scan somehow affected the SSD. Why the regular HDD wasn't similarly affected I can't explain.
Posted by: Sarcany
Date: July 25, 2020 03:21PM
The vibration from the trip may have knocked something loose.
The 1st thing I'd try would be to pull the drive and connect it to another Mac to see whether it's working.
If it seems fine then put it back in the mini and check the drive cables while doing so.
Posted by: modelamac
Date: July 25, 2020 03:48PM
Did you try reinstalling the OS while in Cmd-R? That will tell you if you need to replace the drive (if it doesn't work).
Remember how when you were little
you could just rip off your diaper and
just run around naked and everyone
thought it was so cute and funny?
Anyway, I need bail money.
Date: July 25, 2020 04:36PM
Sarcany
.this
Desktop computers are not designed for portability!
Date: July 25, 2020 04:57PM
modelamac
Not sure how to do that on a drive I can't Repair, or apparently even Mount.
Posted by: btfc
Date: July 26, 2020 01:18PM
Where were you in Wyoming?
Date: July 26, 2020 01:47PM
Essentially the entire perimeter. Denver rent-a-car; Laramie; Jackson; Grand Tetons NP; Yellowstone; Cody; Buffalo; Devils Tower; Black Hills of South Dakota; back to Denver via Cheyenne.
The trip began with six days at my sister's in Texas. I leave a keyboard and monitor there, and just put my Mini in my backpack so I can work essentially as normal when visiting my family.
Guests: 97
