RYF: Extech Multimeter Test Kit (MN24-KIT) $11.50 + Free Store Pick-up
Date: May 31, 2012 11:50AM
[slickdeals.net]
this is made by a company called FLIR which makes some cool scientific instruments. Probably a better device than those cheapies at Harbor Freight. kin includes 3 devices, DMM, non contact voltage detector and outlet tester.
Product Description
Full-featured Multimeter tests AC/DC voltage and current, resistance and diode/continuity test. Also tests 9V and 1.5V batteries. Non-contact voltage tester detects presence of voltage on 120V/240V circuits. Receptacle tester plugs into any outlet and test for proper wiring. Includes test leads.Warranted. UL Listed. Wt. 1.43 lbs.
Re: RYF: Extech Multimeter Test Kit (MN24-KIT) $11.50 + Free Store Pick-up
Posted by: lafinfil
Date: May 31, 2012 12:00PM
Looks pretty much exactly like the one Sears sold under the Craftsman label except this one is Fluke yellow instead of Craftsman black & red. I assume that they may have been the supplier for the Craftsman since this deal is through Sears too. I picked up one a couple years ago when Sears had them for a similar price and it has been a good meter for my use except the non-contact voltage tester did not hold up well. It still works but I don't really trust it so it was replaced.
Posted by: deckeda
Date: May 31, 2012 12:20PM
I'd want to verify the non-contact voltage detector in particular. I have one I never use that came with a multimeter. If it's like mine this isn't a bargain.
Reasons: Mine requires 2 LR44 batteries, which can be crazy expensive for their size, easy to lose and annoying to install. The battery-replacement end cap on the tester is hard to remove. And you have to hold down the pocket clip to turn it on. I borrowed a friend's Fluke, which takes AAs and is always on. Amazing how good design can be simple design.
Posted by: lafinfil
Date: May 31, 2012 12:35PM
The one in the photo looks identical to the one I have which uses a pair of AAA batteries and has no on/off switch. The battery cover is part of the pocket clip and gets sloppy after riding around in the tool bag and becomes unreliable due to poor contact. Still fine for casual occasional use but won't make it long term in moderate to heavy use in my experience.
[www.sears.com]
Edited 1 time(s). Last edit at 05/31/2012 12:36PM by lafinfil.
Posted by: flareslow
Date: May 31, 2012 01:29PM
Thanks! Ordered one.
Posted by: olnacl
Date: May 31, 2012 02:10PM
I went for (another) one too. These bargains are going to break me.
Oh, thanks for the tip.
Date: May 31, 2012 02:16PM
....don't RUN while holding scissors......
Posted by: thermarest
Date: May 31, 2012 02:24PM
Just a pair of probes runs $9 [wwww.sears.com] so its pretty hard to lose on this deal methinks.
Posted by: robfilms
Date: May 31, 2012 02:50PM
i'm in for one.
ymmv
be well.
rob
Posted by: M A V I C
Date: May 31, 2012 02:57PM
In for two. I figure I'll find someone else who needs the deal or it'll end up as a present for someone. Thanks.
Help MacInTouch: Buy from Amazon? use this link [amazon.com]
Mac News & Info: [macintouch.com] [macnn.com] [tuaw.com]
Mac Benchmarks: [barefeats.com]
Used Mac Stuff [FS/T]: LowEndMac Swap List
Mac Software Updates: [macupdate.com]
Fonts: [dafont.com] [fontspace.com]
Online Computer Store With Mac Support: [macsales.com]
Posted by: onthedownlow
Date: May 31, 2012 05:28PM
Got one. Thanks.
Date: May 31, 2012 06:29PM
heck of a deal. The outlet tester is worth about $4-6 by itself. I already have 3 DMMs, one is a Fluke 87, otherwise I'd get another.
Posted by: Mike Johnson
Date: May 31, 2012 10:46PM
Thank you, space-time! I needed another multimeter and was keeping an eye open for a deal just like this. I already picked it up at the local Sears.
I know there are some crazy horror stories about the Sears in-store pickup, but I've used it four times this past week and it's super fast, in & out. By contrast, the last time I actually went into the tool department the service was so bad I swore I'd never come back. It took me 45 minutes to buy $180 worth of froufrou wrenches.
Guests: 161
