wiring light socket
Posted by: wurm
Date: July 02, 2018 11:41AM
Why does every "simple" project seem to turn into a major PITA?
I'm just trying to change out a funky porcelain light fixture in the laundry room. Seems like it should be pretty straightforward. So I undo the old one and see that there are two black and two white wires connected to the screws. Well, try as I might, I can't get the two wires wrapped around the respective screws. Now that I think of it, maybe that's all that was wrong with the older fixture.
Anyway, do I really need to connect both blacks and both whites? Or can I just throw a wirenut on one of each, connect one of each, stuff it all up there and be done with it?
Re: wiring light socket
Posted by: OWC Jamie
Date: July 02, 2018 11:51AM
The proper way to do it is to pigtail the 2 wires existing with a 3rd with a wirenut, attach the single wire to the porcelain socket.
Good Luck!
Jamie Dresser
Other World Computing
Posted by: nwyaker
Date: July 02, 2018 11:55AM
OWC Jamie
Correct. And I wired my whole house...
Posted by: wurm
Date: July 02, 2018 11:56AM
Not sure I understand. There are two screws on the socket; brass and silver. Instructions say black wire to brass screw, white wire to silver screw.
Date: July 02, 2018 12:00PM
And you have 2 black and 2 white. Find another bit of wire - electricity is color blind, does not have to be black and white if you have an old piece of romex (the kind of wire used in your house, I can see it in the box) and cut 8" or so off, make an extension to attach to the socket. Screws are not meant to bind more than once wire to a device unless they have a saddle clamp on them like an outlet, which is designed for one or two wire use.
Like this smiling smiley
Good Luck!
Jamie Dresser
Posted by: GGD
Date: July 02, 2018 12:04PM
wurm
You need two additional pieces of wire, one black, one white. One end of the wire will get wrapped with the two existing wires of the same color using a wire nut. The other end of the wire will go to the screw on the light fixture. Then you need to cram all of it into that box.
It looks like there are additional light fixtures controlled by the same switch, and one of those existing black/white pairs goes to the next fixture in the chain.
Date: July 02, 2018 12:07PM
As noted above. Whomever installed your light socket violated the National Electric Code for.. well, pretty much forever. Especially as far back as those blue plastic boxes have been in existence. It SHOULD look like this:
Posted by: wurm
Date: July 02, 2018 12:09PM
Ahhhh, thanks, Jamie...that picture helped. I think I got it. So basically, I'm making the two wires into one with a wirenut and a third piece of wire. And I do that for both the black and the white?
I guess the next question is, why are there two of each to begin with? I'm not screwing up something else by doing this, am I?
And thanks, cbelt, too!
Edited 2 time(s). Last edit at 07/02/2018 12:11PM by wurm.
Posted by: wurm
Date: July 02, 2018 12:13PM
GGD
That's what I was wondering, but I don't know what they could be.
wurm
Exactly Correct !
You're okay. The socket you are replacing is 'daisy chained' with another socket in the same area (basement ? ). It's a normal approach, just it should have been done with pigtails. Somebody cut corners....
Posted by: GGD
Date: July 02, 2018 12:21PM
wurm
GGD
Since it's an exposed basement you should be able to visually follow the wires to see where they go. One will lead to the switch the other should lead towards the additional fixture.
Posted by: wurm
Date: July 02, 2018 12:23PM
Excellent. Thanks.
Now I guess it's off to the hardware store to pick up a couple of feet each of black and white wire. I don;t see a lot of extra stuffed up there.
Posted by: davester
Date: July 02, 2018 12:29PM
wurm
The second wire goes to another fixture on the same circuit.
Posted by: billb
Date: July 02, 2018 12:30PM
The pigtails don’t have to be black or white although that can alleviate confusion from, say, black’s white and white’s white should you only have white wire available.
[soundcloud.com]
Posted by: wurm
Date: July 02, 2018 12:31PM
Can I just keep the existing ground wires connected as they are after I do this pigtail thing with the black and white?
Posted by: JoeH
Date: July 02, 2018 12:35PM
wurm
GGD
Is the light controlled by a wall switch or a pull cord? Did it work before or were you replacing it because it did not work or worked intermittently?
Anyways, if the light was switched with a pull cord, the light could have been in a circuit that included a wall socket or another light. Depending on local interpretation of the electrical code both are possible, though mixing lighting and wall sockets on a circuit was deprecated in the national code years ago as I understand it. The other fixtures could have worked, or you just did not use that socket. But eventually the improper use of the screw terminals on the light fixture as a bonding point for the two sets of wires could have caused serious problems.
Date: July 02, 2018 12:40PM
......light.....it.....up......
Posted by: billb
Date: July 02, 2018 12:48PM
You could get a green insulated ground pigtail while you are there so you don’t short the bare ground to any contacts
[soundcloud.com]
Posted by: wurm
Date: July 02, 2018 12:50PM
It was a pull-chain fixture with a single bulb. Turns out that light is on the same circuit-breaker as lights and switches in the downstairs kitchen. So I guess that answers the question of what those other two wires do.
Posted by: mikebw
Date: July 02, 2018 01:07PM
billb
I thought the point was that there should be no other contacts that a bare ground wire could ever touch, and if there were then you would actually want the ground to be bare to save your butt!
Date: July 02, 2018 01:48PM
wurm,
If you are going to be handling any other circuits in the house, I would recommend you build a small kit. Get your hands on some of the same gage of Romex wire. A 10 foot roll of 12 gauge will do. That contains all three conductors- Black (hot), White (Neutral), Copper (Ground). You can strip off the outer white insulation and use the insulated wires inside it for pigtails.
Also get a small box of 'wire nuts' suitable for joining three 14 or 12 gauge wires together. 10 should be enought. And also... always have handy one of those little beeper non contact voltage detectors to use for your safety. Always, always, always check the wire before you touch it. It can save your life !
[www.homedepot.com]
Posted by: Mike Johnson
Date: July 02, 2018 02:40PM
And do yourself a favor: watch a video on how to properly use a wirenut to connect three wires.
Date: July 02, 2018 02:53PM
....yes, you need to know the proper way to handle nuts......
Date: July 02, 2018 03:33PM
Mike Johnson
I am sure you will find both correct and wrong videos on YouTube. Can you recommend some videos that you believe show the correct method?
Posted by: wurm
Date: July 02, 2018 03:46PM
Well, it's done. Thanks for all your advice. It was a bit more of a pain that it should have been. I made the mistake of getting a couple of feet of 10 gauge Romex. Got back home and saw that it was just too thick to work with, so rather than making another trip, I ended up clipping a few inches from the existing (there was slack). Then I made my connections with my last two big-ass wire nuts. Of course now I'll have to research to see if I connected the three wires with the nuts properly. smiling smiley
cbelt3, yes that's a good idea. I have plenty of smaller wire nuts, and I already have a non-contact circuit tester. And as a result of preparing for having a portable generator this coming winter, I've re-acquainted myself with (and made a map of) the circuit breaker panel.
Date: July 02, 2018 04:04PM
Wrong way: twist wires together then twist on wire nut.
Right way: keep all wires straight and parallel then twist on wire nut.
I often to both, especially the wrong way for fine (18-20ga wire). Either way, tug on the connection to ensure the wire nut it doing its job.
I am that Masked Man.
Posted by: davester
Date: July 02, 2018 04:11PM
RAMd®d
Sometimes the "wrong way" is the only way to get it to work, especially if you have multiple connectors of different gauges.
Posted by: GGD
Date: July 02, 2018 04:25PM
RAMd®d
Not sure that I agree with this. You want the wires to be in tight contact with eachother so that they conduct electricity directly with eachother.
You don't want the wire nut to be what's conducting between the wires, that thin spring metal core of the wire nut makes an excellent heater element.
Posted by: JoeH
Date: July 02, 2018 04:27PM
12 or 14 G is about all you will need for creating wiring pigtails on standard 15 or 20 A 120 V circuits. Save buying 10 G or larger wire for heavy duty circuits, and usually those are the kind you call in an electrician.
Date: July 02, 2018 05:04PM
space-time
Mike Johnson
[m.youtube.com] is fine
It's important to start with clean straight insulated wire, then strip it, and check it for damage. Don't make a new connection from some bent oxidized wire. Always use the correct size wire nut -- there's a reason they put this big ol
sizing charts on the package. Generally don't pre-twist the ends before putting them in the nut. Turn the nut until the wires themselves are twisted outside the nut. Give it a solid tug. Don't tape it or try to crimp it with a tool.
I'm not an electrician. But by this point I've probably rewired just about every outlet, switch, and fixture in my house. I can't count the number of broken or loose wire nuts, or even missing nuts, I've come across.
Date: July 02, 2018 05:05PM
Agreed.
That's why I'm flexible with a whatever works doctrine. The important thing is making sure the wire nut is secure once done.
I don't know that there's NEC instructions on this, it's just something I've read (you know where) and heard directly from a couple of long-time licensed professional electricians. But a tightly installed wire nut will have all conductors touching together, making solid contact, directly with each other.
Ok, that's just not going to happen. That spring metal in theory could be a parallel conductor, but two pieces of copper wire will be far more conductive, whether or not they're twisted together.
Installing a wire nut will twist small gauge wires, and put no small degree of pressure on heavy gauges that may remain untwisted. A tug confirms that.
Again I use both ways. I don't think the 'wrong' way is more susceptible to some kind of failure. The only problem might be if someone 'pre-twisted' wires say— clockwise, then applied the nut counter-clockwise. I don't see that happening.
So how ever you feel about twisting, tug your nuts, and if it feels good, you're in the right.
Date: July 02, 2018 05:17PM
....like a bird....on a wire.....
Guests: 103
