Kasa vs. Alexa for grouping and controlling smart home devices...any advice?
Posted by: Bo
Date: May 30, 2021 02:32PM
I've been adding a bunch of TP-Link switches and plugs around the house lately. Setting them up through Kasa to function has been easy but I'm struggling with the most efficient way to do groups/scenes/automation etc. Seems like you can do some things in Kasa but others may make more sense in Alexa.
Any general advice on how to approach using the two apps in unison? I'm trying to use Alexa for as much as I can
Edited 1 time(s). Last edit at 05/30/2021 02:33PM by Bo.
Re: Kasa vs. Alexa for grouping and controlling smart home devices...any advice?
Posted by: graylocks
Date: May 30, 2021 03:15PM
I have 7 Kasa plugs but run all except one through Alexa. that one device is on a simple timer in the Kasa app though i do still have it tied into Alexa. i do think the most efficient route is to use one app for grouping so i use Alexa.
Posted by: Ombligo
Date: May 30, 2021 04:57PM
all my Kasa goes through Alexa
“No persons are more frequently wrong, than those who will not admit they are wrong.”
-- François de La Rochefoucauld
Growing older is mandatory. Growing up is optional.
Posted by: Bo
Date: May 30, 2021 10:40PM
Alright…sounds like I’m not crazy that it might be more convenient to use Alexa for the grouping and control end of things
Date: May 31, 2021 11:50AM
I've got five Kasa smart plugs and none grouped or controlled by Alexa.
How do I do that?
Everybody matters or nobody matters.
Date: May 31, 2021 12:36PM
RAMd®d
How do I do that?
first pull them into Alexa. You’ll need to install the TP Link Kasa skill thru the Alexa app. Once installed your app should discover the Kasa plugs when you tap devices. You might also have to tap Plugs.
Do what the app tells you to activate them in Alexa.
Date: May 31, 2021 04:24PM
Anyone else having Alexa "lose" TP-Link/Kasa connections?
This is with Echo Dots & the iOS Alexa app.
(Alexa reports "not responding, check power, yada yada".)
I'm seeing it happening erratically but more often when I turn Wi-Fi off
on my iPhone. It's only with TP-Link plugs yet they all function fine
via Kasa or using the manual button.
Doesn't happen with any of my 'Smart Life' controlled bulbs or plugs.
dunno smiley
DuckDuckGo
includes:
patriot smiley
Edited 1 time(s). Last edit at 05/31/2021 04:25PM by MrNoBody.
Date: May 31, 2021 05:58PM
not seeing it with my Kasa plugs at all. I do have a 2nd gen Echo that seems a little hard of hearing but that's a different issue entirely.
Date: May 31, 2021 07:01PM
Thank you for that, gl.
I'll give it a shot.
Guests: 102
